Abaqus Metallurgical phase transformations simulation example running problem
Adil Memet
DE
Dear All, I have a simple question about Abaqus Document example input file running problem. the other input file ran smoothly without showing error, only this one has showed it. I was wondering has anyone tried it or not ? how to fix the problem. thanks in advance.
Abaqus-->Verification-->Analysis Procedures and Techniques-->Additive manufacturing process simulation-->Metallurgical phase transformations
abaqus job=oneelem_phase_trans_ti64_amprint interactive
Run pre.exe
7/4/2025 7:25:08 AM
Abaqus Error: Analysis Input File Processor exited with an error - Please see the
oneelem_phase_trans_ti64_amprint.dat file for possible error messages if the file exists.
Begin SIM Wrap-up
7/4/2025 7:25:09 AM
Run SMASimUtility.exe
7/4/2025 7:25:09 AM
End SIM Wrap-up
Abaqus/Analysis exited with errors
Error 1: PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
***ERROR: in keyword *MATERIAL, file "mat_phase_trans_ti64.inp", line 1:
Unknown parameter: usertype. The parameter may be misspelled,
obsolete, or invalid.
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
INTERPRET SOME DATA. SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
END PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
Example files: Input files
oneelem_phase_trans_ti64.inp
Single-element analysis of metallurgical phase transformations in titanium alloy Ti-6Al-4V by applying temperature cycles with constant heating and cooling rates.
oneelem_phase_trans_ti64_amprint.inp
Single-element analysis of metallurgical phase transformations in titanium alloy Ti-6Al-4V by applying typical thermal cycles of manufacturing processes.
oneelem_phase_trans_s5140.inp
Single-element analysis of metallurgical phase transformations in steel 5140 by applying temperature cycles with constant heating and cooling rate.
Input files containing definitions or data to be included in the input files listed above
ABQ_phase_trans_types.inp
Types of property tables and parameter tables used by the metallurgical phase transformation framework in Abaqus.
amp_temp_amprint.inp
Amplitude curves representing typical thermal cycles during printing and heat treatment processes.
Material definitions of titanium alloy Ti-6Al-4V.
mat_phase_trans_s5140.inp
Material definitions of steel 5140.
What version of Abaqus are you using ? Is that a student version (Learning Edition) ? It won't work then.
Abaqus 2025 version, not student version, I tried to run it in command , it started, but then "
obsolete, or invalid." showed error.
