Abaqus Inertial Relief Setup
Joey156
Student
GB
Hi Everyone,
I am currently working on a University rocketry team with the computational structural dynamics team- We are currently using Abaqus to perform simulations. From research we have found that utilising inertia relief in our simulations seems to be the right way to go about simulating our unrestricted problems.
At the moment we have been investigating inertia relief on simplified models of our components to determine if we are getting the results that we expect. Our current set up includes is a static general step, applying the inertia relief at the COM. The input model is linked below, but essentially is two block of aluminium connected together via two threaded rods, one of which is representing the COM of the upper half of the rocket. Several pressure forces are applied to one side of the model (representing the thrust from the motor). No boundary conditions have been applied and the only forms of interactions we have used are tie constrains to simulate the threaded connections between the rods and the blocks.
Currently our simulation is converging and we are getting results, however in the results we are observing that the magnitudes of stress throughout the assembly are much larger than expected, we assume that this is due to the assembly experiencing a much larger acceleration that in reality. To confirm this we have ran implicit dynamic simulations and our expectations have been confirmed as the acceleration experienced by the assembly is much larger than the acceleration expected. Any advice with regards to why we are having these results or general advice regarding inertia relief and how to utilise it correctly would be greatly appreciated.
 https://files.engineering.com/getfile.aspx?folder=9c41877a-8fc4-48c7-a129-1236902f8232&file=Static2.inp
Do you compare these results to experimental data ? How are those experiments carried out exactly ? I think that for such problems it would be better to leave static analyses and perform dynamic simulations. However, you may also have to change the modeling approach to get more consistency with real-life operating conditions.
