I am having following error in additive manufacturing modeling in abaqus. I am getting the following error.
Error in job 2LayersAM: The volume of 256 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
Kindly guide
Kindly guide
