ABAQUS 2022 AM Modeler Plugin
dhj21
I am trying to use the ABAQUS AM Modeler Plugin in the CAE to follow the example here :
I think I am pretty close to being able to follow it. I have created the event series, moving heat source, and cooling portions. However, when I try to complete the material input section, for element activation, the event series widget is blank. If I fill out the rest of the information for the advanced and bead tabs and click ok, I receive this message "Data are not complete or invalid for following widgets, Event series."
I have written an input file and the event series are there, and the moving heat source section of the plugin can read the event series.
I just need help determining why the material input section isn't reading the event series.
Thanks.
I realized my mistake. I needed to add an event series for the static (structural) step in addition to the heat transfer model.
