engpes
- Feb 10, 2010
- 175
What are A572 Gr 50 typical charpy impact test values are -20C?
I know this varies quite a bit, but am curious if anyone has a typical range. The typical requirement is 20 ft-lbs at this temp,i believe.
What are the odds / % that a typical US steel mill without any specific post processing would produce A572 Gr 50 with 20 ft-lb results at -20C?
