60034-14 "Machines mounted in situ"
michaelb7
16
The scope of this standard says "This standard is not applicable to machines mounted in situ". Does anyone know what this means?
My motor is mounted to a gearbox by a flange, does that mean this standard wouldn't apply to it?
Possibly motors which are an integral part of a larger machine or device, such that they do not have a frame or casing of their own, i.e the stator iron is mounted directly into the machine. If your motor is a standard IEC frame size and type then the standard will almost certainly apply to it.
