Drawing pyramid in CAD program
  • Thread starter Thread starter wowpilot
  • Start date Start date
W
wowpilot
Guest
I am trying to draw pyramid which consists of 4 equal equilateral triangle (100*100*100). But there is a rule that I have use only 100 mm and 60 degree to draw. But I am not able to draw . There are problems about geamatry
As u can see there is agle which has to be 60,but is not :(
You got a 102.314 dimension, Maybe if you make it 100 also it will make the angle 60
There are many ways to draw this pyramid. Here's what I did (using only the 100 dimension) with the GSD workbench
1. draw a sketch of the first equilateral triangle, with each edge length = 100
2. draw a R 100 sphere (surface) through each of the triangle vertices
3. intersect 2 of the spheres to get a circle
4. intersect the circle with the 3rd sphere, and use Extract option to choose which point
5. draw 3 lines from the point to each of the triangle vertices
6. verified geometry by measuring angles between all the lines
What the hell did you come up with this idea boss ?
U are awesome ;)
This method came from 10th grade geometry class. Most CAD techniques are based on pencil & paper & compass techniques for solving geometry problems.
