structSU10
- Mar 3, 2011
- 1,062
per the title, to accommodate a heavy swivel ring there is a proposed 5" thick plate that would be tapped to accept the swivel bolt. This plate would be bolted to the lifted piece which is 2-1/2" thick.
I was curious on any thoughts for shear of these bolts through such a thick plate. I'm thinking of using the AISC provision related to filler plates (J5.2) where a 15% load reduction is used but not sure if that is appropriate.
