S
sina123
Guest
Hello I am working on 3d experience (CAtia V6) and want to run a CATUTIL- "Drawing Batch" from command line, but its not getting executed and returns object not found. I used the same file which was created when i run the batch manually through the UI.
I used the following:
catutil -Name "Drawing Batch" C:\temp\BatchParameters_10.47.18.xml
but when i use different batch it runs fine:
catutil -Name PLMThumbnailBuilder C:\temp\PLMThumbnailBuilder_19-02-2019.xml
The batch name has space in between the words how can i handle it would that be the issue?
