3D Object Dimensioning
  • Thread starter Thread starter Baldasarre
  • Start date Start date
B
Baldasarre
Guest
Is there a way to dimension a 3D object using standard dimension tool or is there other way around. The dimension line should be parallel to the object and the extension lines should be on an angle.
Hi Baldasarre,
You can dimension 3D object, just be sure that your views are set correctly and set your UCS to the current view.
Enjoy!
