3D note associative feature dimensions?
  • Thread starter Thread starter amar.junankar
  • Start date Start date
A
amar.junankar
Guest
<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
When a standard hole is created in Pro/Engineer, a feature note is automatically created showing different parameters used. I am trying to do something similar for other features. E.g. displaying extrusion height in a 3D note attached to that extrusion feature?
This can be done by adding a parameter at part level, but can it be done by a parameter at feature level. If a parameter is defined in a feature and used in feature setup note, Pro/E doesn
Make sure you attach the note to the feature.
You should be able to insert the dim parameter into the note (&d0 for example). If that dimension is driven by a parameter insert the parameter into the note
Hi Tony,
Thanks for your kind reply. I am able to insert dim parameter in note, but
not the parameter defined at feature level (even though note has same
feature as parent). I believe inserting dimension into note shold be sufficient
in most cases.
Thank you again,
Amar Junankar
Amar
What you could do is the following. You can still show the parameter from the feature. You need to know the feature number and the parameter
ex.:
&TEST:FID_38 (TEST is the parameter and :fid_38 is feature number 38) you can get that from the feature info
Hi Tony,
Thanks a lot!
I really appreciate your help. I was trying to get it work the same way
Pro/E does and then overlooked this FID use.
One similar problem I am struggling is to display a part parameter in a 3d
note in an assembly. I was trying to use session id for part (e.g.
&parameter_name:session_id) but it's not working.
Thank you again for your help.
Amar
the proper syntax for this would be
&TEST:FID_39:4 (test is the parameter, :fid_39 is feature number and :4 is the feature id in the assembly)
Hope this helps
Thanks for reply.
If the parameter is not defined in any feature of part and is directly defined in Part file (e.g. Part_Name parameter), is there any method to display it's value in 3D note of an assembly?
Thank you,
Best Regards,
Amar
Hi tony,
I have one question on this.
can we control decilal places of dimension values used in parameters.
for example: I wolud like to creat a parameter for partdescription like : washer Dia 26 x 0.5 thick.
I want to show the dimensions of Dia and thickness wid two decilal places while the desciption parameter drive by these two dimensions should still show up the way I have mentioned.
thanks
-Rudresh
Use parameter_name[.2] to limit the amount of digits shown to 2.
Sip
Edited by: sip
