2d drawing to 3d
  • Thread starter Thread starter bt1
  • Start date Start date
B
bt1
Guest
hi,
how to convert 2d drawing to 3d drawing
Hi bt1,
First step you should region it
second step extrude it.
hi,
Depends how the 2D drawing looks like. When the object is i.e. a closed polyline you can extrude or revolve it, or you can use sweep or loft by using a path and in the case of loft, using more 'profiles'. So in 2D you draw your Profiles from where you want to make a 3D solid or 3D mesh. Additionally you can draw 2D paths to 'guide' the extrusion. Those paths may not lie in the same UCS-plane.
