stadamack
- Nov 3, 2009
- 12
Hi all,
For a medium size house with a heat pump, the MIC calculation allowing for diversity is at the limit for 16mm PVC insulated cable. Are 25mm2 tails being used in domestic installations with heat pumps in the UK / Ireland?
Other than cost and workability, what are the main disadvantages using 25mm2 in place of 16mm2?
Thank you,
Thank you,
