All,
I am reviewing a foundation drawing for a vertical vessel that was designed by the M.W. Kellogg company in 1965. I need to evaluate the anchor bolts for an additional loading scenario. The original drawing I found only list an anchor bolt code (Size 22, Type CU, P 30) for the anchor bolts. Does anyone have the anchor bolt code used by Kellogg?
Thank you
Thank you
