Dollar store roof collapse 4
JoshPlumSE
I didn't see anything about this in the Engineering disasters forum. So, I thought I'd post it here:
TLDR summary:
In Kansas City, MO, the store front / roof of a Family Dollar store collapsed yesterday (7/27/25). On man was killed an another seriously injured.
Really I'm most curious if anyone from the area knows more about what could have caused this collapse.
While the building looks old and poorly maintained, these sorts of collapses usually occur when there is some event (clogged roof drain, build up of snow loads, wind uplift) that I suspect there was something here that we don't know about that caused any maintenance issues to be exacerbated or exposed.
Per@human909's link...
Car crash 9 years ago demolished the column holding up the corner of the building. It was never replaced.
Pretty straightforward negligence case for the victims.
Wow that is crazy. I wonder if the AHJ knew about it?
I saw it looked like a cantilever, but not replacing a column after it got demolished???
Looks like a pretty good law suit coming up there.
Side note - I have done site surveys in several dollar tree / family dollars (soon to be converted into whatever else) and the back of house of those places are absolute horror shows. Stock rooms stacked to the ceiling with ripped open boxes. Absolutely inaccessible areas of the building due to merchandise being scattered everywhere. Maintenance nightmares. Oftentimes in the lowest rent strip malls in town with the stingiest of landlords. I always left those buildings feeling so bad for the one or two employees who did the work of ten people.
The horror is that you can see obvious deflection problems in the 2017 picture too. It's shocking to me that they never replaced it or at least got an engineering report for it.
I used to do strip mall site surveys for new dollar stores. Didn't see what @dold saw, since they hadn't move in yet, but a lot of those places are pretty sketchy.
That third street view photo...you can see the cladding pulling apart where the roof is sagging. Yikes. I'd hate to be called in as an expert of Family Dollar's side...
@XR250 - just remember, Family Dollar was owned by Dollar Tree from 2015 to this month. So that issue was technically a dollar tree issue.
Can anyone tell what the roof joists are bearing on? They don't look long enough to reach the wall, but I don't see a support beam
Maybe there was a ledgery/corbely type thing sticking out from the wall a bit that was well attached to the wall enough to go with it into the rubble. Hard to tell with the perspective
