RAPID Software Manual Official Link?
artking
Aerospace
Hi!
I'm curious about the RAPID software "REPAIR ASSESSMENT PROCEDURE AND INTEGRATED DESIGN", especially it's manual. Is there an official link to it somewhere? I haven't been able to find it and the best I've seen so far is Scribd.
Thanks!
FYI...
FYI, I was a beta tester for the software back in the 90s. Software was only meant for screening of repairs to determine safety risk following aloha. No real value in the software itself and the method has been proven to be unconservative and so no longer accepted for any analysis.
I believe the procedure described by the Chicago ACO paper (Eastin) and/or the Seattle ACO, augmented by Tom Swift's papers, are still the preferred guidelines for skin repairs and antenna penetrations.
If you absolutely must have the RAPID documentation, say for historical purposes, then see the attached files below.
You will need a PC with Windows 95 or 98 to install and run RAPID. Maybe XP will run it with some gentle coaxing.
In the unlikely chance that you are dealing with a structural failure in an aircraft, and you need to use RAPID is because it was the "substantiation" of a repair/penetration of the skin that has now failed, please let me know. I never deleted the old RAPID stuff from my archives, and could dig up more if you need it.
