Surface colour inheritance option
DaveJFT
Automotive
GB
Hi folks,
I'm finding that when I use a surface feature (from a geom set) in a body through, say, Close Surface or Split (using a surface), the colour of the surface is inherited by the new faces in the body. They retain that colouring persistently until I select each face patch and set its colour manually and then they are independent of the body colour.
Can anyone help me with the setting to prevent the new faces inheriting the colour of the surface features, and/or enforce the use of the body colour?
(V5-6, r2023)
Many thanks
in tools-options:
Mechanical Design-Part Design- "Inherit colors from surface or reference object"
Hi LWolf,
Thanks for your reply. I couldn't make that option do what I wanted but then a colleague found a post elsewhere that said to turn off Advanced Graphics Properties Management and all is now functioning as I desire (for new parts)
