Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
With tension in the anchors which may or may not have been designed for tension.It will develop some moment.{/quote]
You are describing post yield deformations which exceed ASD code values, if, in fact, the OP was designing based on ASD. It doesn't sound to me like the OP was doing a collapse prevention or an ASCE 41 analysis.But to answer your question:
bending of the toe and stretching of the bolt
Not before likely exceeding allowable soil bearing pressures.Any moment developed by the base plate will go into the footing.If the footing was not designed as fixed, it will rotate and relieve the moment.
You are making a distinction between "very small" and ZERO rotation. Even a footing designed as fixed base will rotate. Anything with a load will deform.Once the rotation of the column end equals what it would be as a pinned base (per your analysis assumption), then it is effectively hinged. That anount of rotaion is very small. It should be readily available. A fixed base has ZERO rotation,
I do not agree, but I do acknowledge "standard practice" where based plates with anchors located within the flanges have been considered pinned for a long time. My contention is that this is a business decision in which there have been few failures and not one founded on structural analysis.so it is safe.
The only place where I can see that this could be unconservative is in the moment connection between the beam and column. "Back in the day" before I had software that would do the work for me, I would use the Portal Method to design frames. I would design the moment connection for F x 0.6h and the base connection also for F x 0.6h. A modern day analogy would be to model it both ways and design the moment connection from the pinned based model and the base plate and anchorage from the fixed based model.Really? Surely that could readily be unconservative. The bolt positioning and the plate thickness doesn't lend itself to a high stiffness connection, it would fall in the semi-rigid category, hence my earlier nuanced replies.
The critical force effect in most frames like the OP's would be the moment at the top of the column, and a fixed base assumption just made that a lot smaller. Thus, you need to show the base plate is thick enough to justify fixed. What's the method for that?Fixed.
It would only be unconservative for the moment connection between the beam to column.Really? Surely that could readily be unconservative. The bolt positioning and the plate thickness doesn't lend itself to a high stiffness connection, it would fall in the semi-rigid category, hence my earlier nuanced replies.
Modeling it both ways would be best. "Back in the day", I would design moment frames using the Portal Method using F x 0.6h to design the moment connection between the beam and column and F x 0.6h to design the connection (and footing) at the base.And for the record, to bluntly answer the original question I'd model that connection as pinned. But if I had any inkling that assumption would be unconservative I'd model it as both to ensure missing some important failure mode.
Well yeah and that is a problem. It is typically the most highly loaded areas in a portal fame. It would also be quite unconservative in terms of deflections. (And I'll highlight that both our comments seem to be assuming a portal frame.)It would only be unconservative for the moment connection between the beam to column.
But your previous responses said "fixed" with no nuance. So changing your tune now seems odd.Modeling it both ways would be best. "Back in the day", I would design moment frames using the Portal Method using F x 0.6h to design the moment connection between the beam and column and F x 0.6h to design the connection (and footing) at the base.
I was only addressing the pinned based assumption, which is what the OP was discussing, so the tune is the same. The effects of a fixed base on the beam to column connection is a different verse of the same tune.But your previous responses said "fixed" with no nuance. So changing your tune now seems odd.
It would be interesting to see the moment diagram if you rerun this with fixed bases....
Here is the moment force diagram considering boundary conditions pinned. Units are in kip-in
