Tesla Cybertruck fire and alleged design flaw. . .
Brian Malone
Industrial
This story says a lawsuit has been filed against Tesla on behalf of the family of a man who crashed his CT and was unable to open the electrically operated doors after the electrical system became damaged by the crash, and he perished in the vehicle fire created by the battery in a thermal runaway condition.
I am not familiar with the Tesla door releases - I have ridden in Model 3 and a Y with Uber rides but did not pay attention to the door mechanisms. My cars are 2005, 2009, and 2021 models by Toyota, Nissan, and Buick and they all have a mechanical linkage to actuate their door releases ( electrical locks /remotes move the mechanical linkages).
Those of you familiar with the Tesla doors - is the setup a design flaw for emergency exit? Does this lawsuit have merit for a major safety issue or is this a heart-broken family reacting to a tragic loss. Have other auto manufacturers gone to purely electrically actuated door releases?
They put an emergency mechanical release pull behind an unlabeled removable panel. I think it is hidden this way for two reasons. The first is that everything they do has to be different. Every. Thing. The other is that the mechanism is too weak to be used every time the door is opened and by hiding it they save wear and tear. Why is it so weak? Did I mention that every thing they do has to be different? I have no idea how they decided that this was possible.
I think one other car company did a similar thing - battery dies and door won't open - but I don't recall who.
If you place an "emergency release" where it can't be found in an emergency by the average user perhaps its technically just a "manual release cable". And manual here appears to refer to the need to use the manual to find its location and its mode of operation.
Tesla doors have an inside mechanical release, but it's in a different location from the way users normally open the doors, so they wouldn't necessarily know about it. (Bad.) The cybertruck has an additional problem in that there is no outside mechanical door handle at all. (Very bad.)
Tesla isn't the only manufacturer to go to flush exterior door handles whose operation is not necessarily intuitive.
I don't understand what's wrong with a plain ordinary mechanical door handle, inside or out, that you just pull to unlatch the door.
It isn't an EV thing. My Chevy Bolt has plain ordinary mechanical door handles, inside or out, that are easy and intuitive to use.
Putting the manual release behind a panel is complete stupidity.
Other cars do have electric door latches. Later model Corvettes do. The manual release is a pull-up lever between the seat and door, one on each side. Easy to reach and pull as long as you were shown it's there.
BMW. Battery dead, can't open the doors. YouTube video; just open the hood and back-feed power from the under-hood light.
Ya, just open the door and pull the hood release, and then you can back-feed to open the doors.
The SUV was in pretty bad shape. The doors were still locked when it went to the shredder.
Interesting an electric door release without a mechanical scheme is able to pass a reasonable functionality/hazard mitigation review for use in a passenger vehicle.
I recall that one of the reasons for the Tesla push button opening/unlatching is supposedly to give the electric window a chance to retract a few millimeters out of the seal channel at the top of the door. This is to reduce wear on the seal, though I had a car for 30 years that had glass against the seal and it didn't leak and didn't wear out. However they could have used a mechanical release and include a cam and either a microswitch or any of a number of contactless sensors that would drop the window before taking up engineered backlash to disengage the latch.
From the manual:
Opening a Rear Door with No Power
To open the falcon wing doors in the unlikely situation when Model X has no power, carefully remove the speaker grille from the door and pull the mechanical release cable down and towards the front of the vehicle. After the latch is released, manually lift up the door.
Yup, behind the speaker grill which is down in the foot-well area of the door.
The front doors have a hidden UI; it's not behind a panel, it's designed to look like a trim piece and has no label.
A system that releases all of the latches upon detection of a crash or fire might be simplest to implement considering all of the remote operated hardware is already there.
There were some car designs that did that sort of thing on a dynamic basis - referred to as ejecto-matics - where the door latches would fail mid-collision and allow the occupants to either be released or be guillotined as the vehicle rolled over. The trick is for the car to be able to unlatch the doors, but only after the entire event is over, but before the electrical system is too disabled to function. That's a pretty narrow path.
On a lighter note, I am now getting Tesla recommendations, this one showing how Tesla has a better idea to make sure the cabin filter is a soaking wet home for mildew:
I can say that Toyota managed a similar trick, but in a different way, on the Rav4; they made a cover that keeps water from raining down the cabin intake, but they heat staked that cover. After a few years the heat stakes cracked, not enough to break, but enough for capillary action to be drawn in and drip. It was only a problem when hours-long rain fell, so every early cure I tried seemed to work as pushing a high velocity hose stream onto the area saw no water enter. Had they put the posts on the cover and heat-staked from beneath, it would have been fine.
Still, the Tesla air intake is going to be a problem from day 1 as that design is guaranteed to fail.
Electric latches and door poppers have been around for decades, just not on mainstream vehicles. I vaguely recall seeing an old NHTSA bulletin clarifying that the requirements for a "latch" in FMVSS meant a mechanical one. Regardless, common sense should dictate that it exist and be visible. Crash requirements have driven higher belt-lines and thicker doors on modern vehicles which make them more difficult to climb in/out via the window.
You're assuming that a certain manufacturer actually does FMEAs, as opposed to "yes, boss, we'll make that work".
"Interesting an electric door release without a mechanical scheme is able to pass a reasonable functionality/hazard mitigation review for use in a passenger vehicle."
Yeah, having lived through the rollout of systems engineering and SPC in a car company I can see that FMEAs are not the Tesla way, and therefore there will be consequences.
Things like this should be captured by basic certification rules. FFS all the fine detail that has to be ticked for lighting, glass, vehicle dynamics, crash-testing . . . And now it appears that being able to open the door in an emergency is a feature that will have to be tested in the courts.
In the BMW the key does not operate a lock mechanism. The key activates a switch, so with a dead battery..........
Most of the rules were written before there was such a thing as electronic controls.
All risk assessment procedures, FMEA included, are subject to some degree of subjective evaluation. To what extent do you address combination failures? How do you estimate the probability of an event occurring, especially if new technology is involved? At what combination of risk factors do you judge the situation to be acceptable? And, to that point ... what happens in court a few years down the road when that miraculous combination of factors does indeed occur, and you have to defend it from the lawyers who of course have 20/20 hindsight and say you should have foreseen that situation happening? The extent to which you FMEA a commercial aircraft, and countermeasure the failure modes, doesn't make sense for a ground vehicle that can pull over to the breakdown lane instead of falling out of the sky, and even if you tried, what good is it if the cost of the vehicle is such that its target market can't afford it and keeps on driving their '84 Plymouth Reliant with no airbags, no ABS, no ESP, no back-up camera, no pedestrian alert, no lane-keep assist, no countermeasures against small-overlap frontal crash, etc etc.
That said, I wouldn't be opposed to something in the motor vehicle safety standards requiring all passenger entry doors (not just the front ones!) to be openable with or without vehicle electrical power available, including being openable from inside with or without electrical power available even if the door had been locked to inhibit outside opening, and the ergonomic means by which the door is opened without electrical power be the same motion as the one used to open it with electrical power available. (If you're going to use a latch-popper button, put it ON the physical handle that you mechanically pull to open the latch if the power isn't available, with actuation in the same direction - if the electrical latch-popper button doesn't work, just keep pulling the handle further. None of this burying the mechanical latch under a cover in a different place from where the button is).
What happens in a crash if the mechanical release inadvertently opens the door or releases the latch?
My GM pickups have had this covered. If the door handle is inadvertently operated during a crash, the doors don't unlatch. If you need to make an emergency exit, pull and release and pull again. The second pull of the door handle unlocks and unlatches the door.
This is also handy if a driver stops to allow a passenger to exit but doesn't put the transmission in park.
The doors have locked automatically and stay locked until the transmission id put into park.
No problem. Just pull twice and exit. (Carefully in case the driver releases the brakes and the vehicle starts to move.)
"To what extent do you address combination failures?"In automotive we don't. SPOF only as a general rule. There may be exceptions.
One would hope that battery / electrical system failure / compromise as a result of a collision impact is considered. Normally the point at which the airbags and seat-belt pretensioners fire, is before there is significant compromise of the bodyshell, and one would think that the signal to fire the airbags coincides with another one to unlock (not unlatch - just unlock) the doors, and another one to initiate the 4-way flashers, in case the electrical system maintains enough integrity for all that to work afterward. I'm sure I've seen IIHS partial-overlap crash videos in which the battery could be identified among the flying debris ... airbags had already fired.
The cybertruck has an external-rescuer issue in that it has no exterior door handles. Even if it unlocks the doors, then what? Someone outside the vehicle still can't open the door. If it unlatches the doors during a collision, that risks having them fly open.
. . To what extent do you address combination failures? How do you estimate the probability of an event occurring, especially if new technology is involved? At what combination of risk factors do you judge the situation to be acceptable? . .
Shouldn't be a huge leap to group all the failures that are likely to occur in a collision, assume they might all occur simultaneously in such an event and mitigate accordingly.
