Vapor recovery unit (VRU) design and methodology
RistEcho
Chemical
Apr 10, 2025
3
I've been asked to review some VRU designs for a tank terminal containing HC (activated carbon beds with PSA followed by a scrubber), but admittedly I do not have hands-on experience with VRUs so would like to seek everyone's experience. Design is for 1000 NCMH.
Couple initial questions:
1. Tank products are mainly gasoline but do include heavier HC. Most VRU designs call for adsorption with activated carbon bed, followed by desorption/regeneration at 25-50 mmHg for 10-15 minutes cycles. Are these vacuum pressure and duration settings enough for full regeneration? I'm a bit incredulous because the heavier HC will be harder to desorb, and I worry that they will accumulate over time to kill the effectiveness of the VRU.
2. From what I understand, adsorption of lighter HC (e.g. ethanes) by activated carbon is poor. Does the adsorption truly improve with specialty activated carbon pellets (I saw a quote for a specialty 4mm cylindrical activated carbon product that was multiples of the price of a "generic" brand)?
2. Vacuum pump - From what I've read, it seems that the top reason for VRU failure is the vacuum pump. Do people have a favorite type (or brand/model?) for this application? I understand that oil seal vacuum pump seems to be most popular, but I would prefer to rely on advice from folks with real VRU experiences.
Thank you!
Agreed, low temps will be required for adsorption of ethane on to activated carbon, but then there is next to no ethane in gasoline.
Check with those guys.
[/URL]
A google search keys words Ethane vapor recovery unit is another option.
Notes: Three concerns about carbon bed, the regeneration process and how to dispose the material at the end of its shelf life,
the risk of self-ignition of the bed when saturated with HC.
To me you should consider working with people in the field, define your needs (specification), ask for a quote and guaranties.
In some countries it is very difficult and expensive to dispose AC (China is an example).
Good luck,
Pierre
I dont have direct experience working with or in the design of activated carbon adsorption units in gasoline tank VRU service. There doesnt seem to be a grade of mole sieves that would enable this adsorption of heavy hydrocarbons ( paraffins + naphthenes + some aromatics) from an air stream at ambient temps, and the closest appears to mole sieves 5A - talk to Dow Chemicals to confirm and explore. Otherwise, see if this document helps:
