Let me go back to the question again: The customer wants help to ensure they manage the interfaces well in new aircraft (not just the wing) across all products attaching to the airframe. Its a bid proposal. The customer is not disclosing how they plan to manage the issue nor what project management system they follow. It is known that customer's last whole aircraft project was badly managed resulting in a very prolonged design & certification phase, partly its systems integration. Reading between the lines, it seems the question is more to do with 'how do we ensure we have smooth integration of components and assemblies onto the structure so as not to repeat the last fiasco'.
The question may have more to do with the smooth flow of design coordination and assurance and it may be impacted a lot by the procurement of equipment, how RFQ are developed, specification management, contract delivery milestones, etc. If this is the case, it can have more to do with the realism of design expectations, available state of the art, technological risk and how all that is handled in project control. Well its not a break the sound barrier job here. Its a composite airframe with standard engines and it is suited to particular niche market in the utility industry.
Read on if you are interested and any comments would be appreciated!
Examples that come to mind are: that the equipment supplier is not aware of the specific design needs or ignores them until it is late in the design cycle, or cannot deliver on time, supplier will not adjust their interface to meet the available interface, airframe developer does not insist on firm supplier equipment specification until late on, landing gear behaviour differs or is more complex than original elementary specification-creep of specification-revise the LDG, takes time, schedule blows. If there are two big areas where all this becomes a serious issue and that is Engine and LDG. Unexpected things happen but design assurance and several responders pointed out, means putting design management on the job not taking it out.
This mal coordination happens in the best of projects, the cabin team makes changes to the airframe which are approved by cabin but airframe team would not accept-not known till after the event. Same for Avionics, unauthorised changes perhaps not seen until they are a problem, airframe design team has already departed, so questions remain and become a cost for rectification and a delay. In another case, holes were drilled into the spar flanges for P clips to support a wiring loom across the full length of the wing, not ideal, its all about coordination. The loom was not in the DMU.
The traditional approach to airframe development is FAR's, Acceptable means of compliance, testing at material, part, sub assembly, assembly and full integration level, airframe structural tests and flight tests. we can see that rather nicely in the following AC for fuel systems. Note that it does not tell us to do structural test, or manage the interface question for us, let alone tell us what to do at the interface of say a fuel pump mounting in the tank. It could never all be specified in a cook book solution.
https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_25.981-1C.pdf
It seems to me that there is design compliance, real design iterations including interface issues between airframe designers and sub system suppliers that just have to be worked out together, then other project consideration like future provision for events during service life, damage, fatigue inspections interval justifications, etc. These all affect the interface just as they do any piece of structure, but inexperienced project management often assume that integration of system to airframe does not require overlap between teams working together during the design phase, or that it is OK to leave it to last minute to integrate it all together or not even put design management on the interface design coordination. It happens on the biggest project that this is overlooked also.
