Hey Guys,
I am working on a project where I'm considering sistering an existing wood beam with steel channels to help with DEFLECTION.
It seems this is a common solution but I have a couple of concerns:
1. With critical slip(especially if using bolts), don't I need to basically just consider the channels as taking the entire load and deflection or is that overly conservative?
2. I feel like lateral torsional buckling is a concern in the channels and I'm not sure if this has been discussed but would be interested to hear if my worry is misplaced.
Please let me know your experience with this detail. Have you used it alot? Do you feel comfortable with the concerns I mentioned?
Thank you!
Thank you!
