Unspillable bottle
taj05
Student
I am developing a drinking bottle that needs to be completely or as much as possible unspillable. The drinking interface (the whole where the liquid comes out) needs to not have any valve that opens when pressure us applied. Could a labyrinth path for water to escape reduce how much water will apill out when the bottle hit the floor from a height. Will Ventury effect make it worse? Any other idea to solve this?
thanks for your help
Reducing how much water spills out by just using a labyrinth path would also reduce how quickly the fluid can be drunk, which may be undesirable, depending on how much you restrict it. Also, this design means that if you want to drink faster, you also have to accept faster spillage. It's also not really any better than just a cap with a small hole in it, which is much simpler, so I don't see the point of the extra components.
There are plenty of existing solutions to this problem (allowing water to leave a bottle when you want it to, and stopping it from leaving when you don't want it to). Have you already looked at the various existing solutions to this problem, determined their shortcomings, and identified which shortcomings you intend to fix?
Also, this should be in the student forum. I've marked it to be moved there.
If "the liquid" is at all sticky you will have a lot of trouble cleaning a convoluted flow path.
Cool concept! A labyrinth path could definitely help reduce spills by slowing the flow, especially on impact. Just watch out for the Venturi effect—it might actually draw liquid out faster if air flows through too easily. Maybe try combining a narrow zigzag channel with a slight upward curve to resist flow naturally. Looking forward to seeing how it turns out!:)
