Fuel Bladder Testing 1
Rooman789
Aerospace
Needing guidance on the proper NFPA code to begin research on the guidelines needed to use a fuel bladder outdoors for testing/research. Will have a canopy cover with open ends for ventilation. Not close to any flammable structure. Using JP8 as the test fuel.
I do hope you get an LPS for dredging up the exactly correct answer ...
I'm kinda surprised You are NOT simply hooking-up to metal tank/tanker-trailer.
Nonetheless there are a LOT of Factors to consider...
FYI Related... ??
MIL-PRF-32233 TANKS, COLLAPSIBLE, 3,000, 10,000, 20,000, 50,000, & 210,000 U.S. GALLONS, FUEL
MIL-DTL-83833 3000 GALLON AERIAL BULK FUEL DELIVERY SYSTEM BLADDER
MIL-HDBK-510 Aerospace Fuels Certification
MIL-HDBK-1008 FIRE PROTECTION FOR FACILITIES ENGINEERING, DESIGN, AND CONSTRUCTION
MIL-HDBK-1022 PETROLEUM FUEL FACILITIES
MIL-STD-3004-1 QUALITY ASSURANCE FOR BULK FUELS, LUBRICANTS, AND RELATED PRODUCTS
3COE CEGS 11145 AVIATION FUELING SYSTEMS
UFGS-33 08 53 AVIATION FUEL DISTRIBUTION SYSTEM START-UP
AFP93-7 PRIME BEEF MANAGER'S HANDBOOK
COMDTINST 16450.1 SPILL PLANNING, EXERCISE AND RESPONSE SYSTEM (SPEARS)
SAE ARP5789 Aviation Fuel Facilities
I had the same question: Base Engineer Emergency Force. Google will give you references...
Prime BEEF folks deal with contingency and bare-base 'temporary operations'... soft-sided fuel tanks, plumbing/pumping, spills containment, fire prevention, etc... are part of what they have to deal with.
