Wooden Fence - Residential 1
bigmakattak
I am doing an engineering look at an existing 7' -6" high wooden yard fence in Oakland Ca. The fence has 4x6 posts with 8 foot spacing. I am not used to wind designs and don't have software available. From some charts the base wind speed looks to be 92 mph and then an allowance for reducing to about 71 mph for the working stress method. From some calculations that I did with the 4x6 in weak axis bending the post seem to be in the vicinity of 1500 psi for bending stress which is quite high for Doug- Fir posts.
I am looking for some assistance on whether my approach looks reasonable and to see if anyone has a quick method/idea of whether this works or not just by your experience with fences. Hoping to not have to cut it down to 7 foot high which does not need engineering study.
Thanks you!
Forgot to mention that the fence is solid with no openings.
You don't need software, use ASCE 7-16 chapter 29.3.1 for your loading. You don't reduce your wind speed for working stress (ASD), you use the appropriate load factors for the demand. In this case 0.6 time wind load. Converting the wind speed is an old approach.
For the post you can use a Cd = 1.6 to increase your allowable stresses.
TLDR it probably doesn't calc out.
I've got a fence post and post footing design guide at https://fencedesign.com that simplifies the process quite a bit for non-engineers, or engineers that don't have a wind background.
I don't have Douglas Fir strength tables, but I can add them if that is an option in some localities. I was waiting to add more species until I found out what other folks were using. Pine and cedar are all that are widely available in my area.
For Oakland, CA, ASCE 7-16, Risk Category I, I'm seeing 87 mph basic wind speed per the ASCE 7 Hazard Tool: https://ascehazardtool.org/
I usually assume No. 2 if I don't know the specs
Thank you all so much! Information provided are the pieces of the puzzle that I was missing.
Much appreciated.
Bigmakattak
