Txf DGA sampling question
Latango
AU
There's been a question raised about DGA sampling methods in our organization. The procedure calls for filling both a syringe and a 0.5L glass bottle. The question is, how much airspace should be left in the top of the 0.5L bottle to allow for expansion? The opinions range from "a little bit" to "sample it while it's hot and leave no airspace at all". The latter is a possibility if the txf is either online or recently isolated, but units in storage are probably going to be a little under ambient temp.
The vendor specifies an aluminium flask, and leaving a 10-15mm gap, however we do not have access to any aluminium flasks.
See-for information:
tv0009-fa-oljeprøve-2019_a4_engelsk
PDF (new.abb.com)
PDF (new.abb.com)
Yeah, that was the vendor's procedure we have been using, but the oil processing lab, as well as other individuals in the organisation, recommend sealing the glass bottle/plastic lid up with zero air gap. Looks like there isn't an international standard on this sort of thing.
Thanks for the input.
