In my company we have different maintenance concept with requirements to PRV/PSV on HC compare to steam. All in all I think a spring operated valve have more or less the same requirements independent of what media. To reduce the scope of discussions, my question is applicable for valves specified in API 526.
All PRV/PSV. I'm familiar with the acceptance criteria and difference in ASME SEC I and VIII, but are there other criteria? Can I specify +- 3% as acceptance criteria for all types of valves?
Maintenance in one way or another what we do will be more or less as API RP576.
Leakage test according to API 527 which accept a small bubble leakage. Is the requirement for leakage 0 in steam valves? 0 on steam or gas (N" or air)?
