NX 2212: Subtraction error....... 4
CAD2015
Automotive
This is a very simple operation and never had this problem.
I created a tube using extrusion of a sketch circle:
The subtract tool doesn't perform. There is just a shadow of the operation, without cutting.
Where am I wrong?
Thank you!
Perhaps you have inadvertently chosen "intersection" instead of "subtract"?
If not, try giving the cutting extrusion some length in the -Y direction so that it does not start on the same plane as the tube.
If it still does not work, try examine geometry to look for issues.
Thanks, Cowski.
I had the same initial thought before; I double checked, I chosen to subtract.
It almost looks like you have two solid bodies. Try using delete body and see how many Solid Bodies you have. Kind of cool issue. ugh.
Yes, it's strange......
Try changing the boolean option to "none" then try to subtract in a separate step at the end. This might give you a more verbose error message if/when something goes wrong with the subtract.
Is that second extrude a solid body and not a sheet body ?
You have that option in the extrude dialog.
I am getting closer.......
There are TWO solids, I have no idea how that has happened.
Below is a picture showing the two solids (I gave the different colors, for evidence and place them in "Show" and the other in "Hide"...
I do not know why the Extrude (2) has two solids! Creating a subtraction would cut a solid, but the other one would not. That's way the subtraction seemed to fail: there is another solid underneath! And deleting one of them would erase the other one, as well!
What do you think has happened?
A glitch?...................
Thank you!
P.S. I attached the new NX 2212 file, for eventually investigation.......
Check your sketch. I created a sketch with 3 circles (2 identical) and extruded the feature curves. I got 2 solids from one extrude. Maybe the sheet body comes from an almost complete full arc.
Mmaulin,
Yes, your reply solved the problem.
The sketch had and extra curve, overlayed on another.
Thanks a lot!
(y) :):):)
I am laughing of myself: how could I have done such a thing?!!!!!...............
Mmaulin,
Thanks a lot!
(y) :):):)
i've been there... Probably why i'm bald. I pulled out all my hair years ago!
I understand you very well.
I had the same reaction....
