Hello All,
AWS D 1.1 states oxygen cutting of QT material is prohibited. The material under consideration is ASTM 517 Gr F. Is it still valid if i go with oxygen cutting or else shall i consider other option?the under consideration is fabricating steel liner for hydro power project on remote part of the country. Is there any further consideration to be considered with oxygen cutting for edge preparation?
The suggestions are highly appreciated.
Thank you
Thank you
