I'm currently researching vibration isolation methods for a residential project where a rooftop mechanical unit is supported by wood framing. I’m curious if anyone has dealt with a similar setup and can share their experience.
- Would it be more effective to isolate just the equipment base, or the entire platform supporting the unit?
- If the structural framing is experiencing noticeable vibration, is it appropriate to place isolation pads between framing elements (e.g., between a wood column cap and a girder or beam)? Or would that compromise structural integrity?
