deemtocomply
I'm currently designing foundations for a three-storey apartment building located near the coast. The geotechnical report indicates sandy soil conditions with a high water table (approximately 1.5 meters below ground level). I'm considering the use of concrete piles, but I’m unsure whether this is still a suitable option under these conditions.
If concrete piles are viable, what additional factors should I take into account? One concern is the potential for reinforcement corrosion due to the aggressive environment. To mitigate this, I'm planning to increase the concrete cover and possibly control the crack widths in the piles. Would these measures be sufficient, or should I consider an alternative foundation system?
