In PIP STE05121 Application of ASCE Anchorage Design for Petrochemical Facilities it says the following:
“In the case of larger diameter anchors, the only relevant applications for using a sleeve are to provide stretch length to meet the requirements for the anchor to be a ductile steel element or where the anchor will be tensioned.”
Would it be structurally acceptable to wrap the anchor bolt with Bond Breaker Tape instead of using a sleeve to meet the requirements for the anchor to be a ductile steel element or where the anchor will be tensioned?
Comments/suggestions are appreciated.
