Steel Pile Capacity for Lateral Loads & boundary conditions 2
Cosmos88
For a steel driven pile, I would like to check the bending strength when subjected to lateral loads. I've seen that the pile is considered a cantilever beam and the effective length factor is taken as K=2.1 which complies with the assumption. The point of fixity is assumed to be 1 ft from ground level, and Lpile is being used to determine moments and deflections. I don't like the idea of just considering the pile to be fixed 1 ft below ground level and I was wondering if other boundary condition besides "fixed" is being used out there for steel pile capacity or if other methodology altogether is a better approach to describe the pile condition. The pile main function is to hold light weight electrical equipment.
Lpile can determine the point of no moment. 1ft below grade sounds pretty low for typical piles. If you are using Lpile why not just determine the pile moment from that program?
Thank you for answering, I can get the pile moment from Lpile but what about the pile moment capacity? which restrained consideration is appropriate to determine the max bending capactiy of the pile, fixed? is the cero moment region the region where I can consider the pile fixed? Or if someone could point me out to some references explaining the design criteria.
Thanks again, I am not knowledgeable in this area.
The point of fixity ( virtual fixity where max. moment would develop ) depends on the size and rigidity of pile and soil conditions . Typical should be around 5D not 1 foot below. You can perform FEM analysis assigning lateral soil springs or software Lpile ..
From the AASHTO bridge design spec 9th Ed.:
10.7.3.13.4—Buckling and Lateral Stability
In evaluating stability, the effective length of the pile
shall be equal to the laterally unsupported length, plus an
embedded depth to fixity.
The OP looking for stability check of the pile . In my zone , depth of fixity is understood as the equivalent length of a free-standing pile with a fixed base, from which buckling check can be calculated using conventional structural design methods. The following figures from the book
Pile Design and Construction Practice ( By Tomlinson)
HTURKAK, the diagrams you posted match the ones from AASHTO for the depth to calculate L - 2nd time moment goes to zero for free head and the 3rd crossing point for a fixed head.
The potential discrepancy is that the text of the AASHTO spec indicates that is the effective length (K*L), rather than just L. For a fixed head pile, K would typically be take as 1.0, so still the same effective length for that case. However, for a free head, where K would typically be taken as 2.1, that would be a significant difference. I'll have to look and see if that provision is supposed to be applicable to free and fixed head piles.
@BridgeSmith AASHTO and @HTURKAK's aren't
equivalent. AASHTO method needs full pile length analysed with springs or finite element like Plaxis. Hturkak method just needs one fixed node below ground to approximate soil structure interaction. AASHTO also calls it fixity when no bending moment below that level. Hturkak's is near maximum moment. But your code clause 10.xxx and commentary diagram C6.xxx are from different chapters. Might not be compatible? Fixity level different in different contexts?
Also K=1.0 will be right for free head as well as fixed head because AASHTO says use P Delta analysis. Bending moment shouldn't be underestimated so don't need K=2.1 to compensate.
@Cosmos88 Need some details to provide specific answer otherwise have to be general to cover all bases. Cross section, loading, soil type and pile embedment length.
Depth to fixity that Bridgesmeit and Hturkak posted are usually for compression stability and for analysis of bending moments. I don't know anything specific for restraint against lateral torsional buckling but Hturkak method probably as good as anything.
Using P delta does not mean K=1. To use K=1 you need to use a direct analysis approach, which includes some stiffness reduction as well as P little delta analysis.
I have looked up 2012 AASHTO. It used standard Davisson method for fixity depth wihich is probably same as Hturkak's book. Also says to consider pile head fixity for unbraced length so maybe doesn't do direct analysis always. Didn't read analysis/design section to get to bottom of that. But K depends on analysis method.
@canwesteng Stiffness reduction depends on code. We don't do it in Australia but still K=1.0. But I guess AASHTO will follow other American codes.
It usually is fairly well in line with the other codes - AISC, ACI, etc. When it comes to pile buckling analysis, it's consistent with AISC in most aspects, except provisions that aren't applicable due to the unique constraints imposed in the AASHTO spec, and the conditions specific to transportation structures.
