SE2607
- Sep 24, 2010
- 304
I tried Woodworks many years ago and didn't find it productive at the time. I found it too tedious for single member design. For an entire framing system, it didn't provide a "final" analysis, but a "conceptual" analysis (based on my feeble memory, I could be in error with the terms). That experience discouraged me from even trying the shear wall module.
What I did instead was create a beam spreadsheet. I now build a workbook with many beams. Instead of inputting uniformly distributed loads, I enter the tributary width of the load type. When a beam is supported by another beam, I link the worksheets. With ACAD on one screen and Excel on the other, I can easily measure spans and tributary widths and enter those values in the spreadsheet. Once the beams are sized, the supports (mostly wood posts in my practice), can be easily designed by linking the reactions of the beams to the posts. After that, the foundation can be designed using the loads on the posts. It took quite a bit of work to get here, but I have a hard time believing there is a faster method. Maybe it would be if my structures were more complicated, but it has been sufficient for me.
Of course, in my mind, the Holy Grail(tm) is to enter a complete framing plan and have the entire building analyzed.
Last year, I experimented with RISA 3D to do just that, model an entire building. Maybe if I had not built a library of beam templates, a post template and a footing template, it would have been a good solution. However, based on the fact I had those resources, I found building a RISA model for my structures to be more work than it was worth. It was fun, though. I was able to see secondary stresses (and deformations) I wouldn't have seen using spreadsheets. For example, it was interesting to see how much a wall will bow when a ridge beam deflects. Alas, the entertainment value was not worth the price of the subscription to me.
My question is: has Sizer improved? Is it worth looking at again?
Thank you
Thank you
