Max allowable pressure drop for control triple eccentric butterfly valves
Fat Tony
RU
Dear All,
I am writing to ask if anyone has any information about the maximum allowable pressure drop for the triple eccentricity butterfly valve that is used as a control valve. I have found that the information provided by the manufacturer, Belimo, indicates that it is 3 bars.
If anyone could provide any standards or references where this information is described, it would be greatly appreciated.
Thank you in advance for your assistance!
So you mean is there anything which states the maximum differential pressure across a butterfly valve is 3 bar?
This is vendor supplied data.
There is no "standard" I am aware of which states this, nor should there be.
Try another vendor if you want higher than 3 bar.
Do you mean for use as a throttling valve? In this case the allowable pressure drop depends on a variety of factors (eg. the outlet pressure). Cavitation is a particular concern.
What is your application?
Dear Pointsman, hello!
Yes, you`re right, I want to use it as a throttling valve.
I am assuming that outlet pressure will be higher than 0 and even higher than vapour pressure of the liquid.
As per sizing software, in this case, sigma is Ok, there won`t be any flashing or cavitation. But I want to understand where is a limit for a delta P for a butterfly valve, when I should use another design, for example, segment ball valve.
The guys that teached me, told me that the max allowed delta P for butterfly valve shouldn`t be higher than 1-1.5 bar, but I want to clarify for myself is it true or not.
