Mar 20, 2025 #1 I Iman@123 Mechanical Feb 19, 2025 11 How can I run a Umeshmotion Subroutine in abaqus CAE 2025, because I heard the in abaqus 2024 I will not need any compiler to run it
Mar 20, 2025 #2 FEA way Mechanical Nov 13, 2018 5,144 Do you want to model contact wear ? Because indeed new versions of Abaqus have built-in Archard wear model and there’s no need to use UMESHMOTION for that. Upvote 0 Downvote
Mar 21, 2025 Thread starter #3 I Iman@123 Mechanical Feb 19, 2025 11 Yes I want to simulate contact wear. How can use the built-in model, what are the steps? Upvote 0 Downvote
Mar 21, 2025 #4 FEA way Mechanical Nov 13, 2018 5,144 Check the documentation chapter Interactions —> Contact Property Models —> Mechanical Contact Properties —> Contact Wear in Abaqus 2024 (or newer) documentation. It’s described in detail there. Upvote 0 Downvote
