Adaptive remeshing and Swept ? Structured meshes?
Bradley_123
Automotive
Mar 8, 2025
3
Why does ABAQUS not allow me to adaptively remesh with Hex elements. or for that matter, it also does not allow swept mesh and structured meshes. What is the workaround to this?
Well, that's the main limitation - in the case of solids, only tetrahedral meshes are supported by adaptive remeshing. That's because such meshes can be easily generated for pretty much any shape while hexahedral mesh creation is more manual and limited to rather simple shapes.
When it comes to alternatives, you could use ALE adaptive meshing. Or mesh-to-mesh solution mapping but it's more manual approach.
Structured meshing and Sweep meshing technique results in a ordered sequencing of the elements. Say, if you have a rectangular part (with no cutouts or without any stress risers), you can use a structured mesh in this case. Say, if you have a small circular cutout (or a crack), you can have rings of nice looking elements around the crack tip or the circular cutout (by using a swept meshing technique).
Adaptive remeshing needs to refine the mesh, in the region where the error variable reports a higher value and needs to coarsen the mesh where the error variable reports a smaller value. So, it needs freedom to control the mesh. The 'Free' meshing technique gives this freedom (since it results in a random mesh and there is no ordered logic in a free mesh), and this is something that adapative remeshing can work with easily and can move around the elements.
When it creates new elements in a region of stress concentration, you cannot always ask it to fill it up with only hex or quad elements (if 2D). It is more easier to fill up the gap using tri or tet elements. Remember that tri and tet elements can fill up any complex shape, but hex or quad cannot.
Best Regards,
Vishakh Rajendran.
