Assistance with FEM Simulation of Continuous Rotary Extrusion in Abaqus
Nilsc15
4
Hello everyone,
I am currently working on my master's thesis on the FEM simulation of the continuous rotary extrusion process and using the FEM software Abaqus for this purpose.
Model Description:
Figure 1 shows the setup of my model. In the continuous rotary extrusion process, the billet (red) is driven by the friction and rotation of the rotating wheel (yellow) and pressed through a die in the tooling assembly (green).
r/Abaqus - Assistance with FEM Simulation of Continuous Rotary Extrusion in Abaqus
Problems in the Simulation:
During my simulation, I repeatedly encounter the following issues:
  1. Excessivly distorted elements
  2. The billet moves past the counterholder
  3. Warning message about overlaps between the billet and the tooling assembly
-the error "Excessively Distorted Elements" causes the simulation to terminate.
The attached figures show my current settings for contact conditions, step parameters, material data, and boundary conditions. Additionally, I have activated ALE.
-material data for the billet
-the contact properties
  1. Contact conditions between the billet and the counterholder as well as the die 2. Between the groove of the rotating wheel and the billet 3. Between the tooling assembly and the billet // all with hard contact for normal behavior
I used general Contact with individual property assignments.
The rotating wheel rotates at 1r/time and is initially accelerated linearly
Has anyone experienced similar issues and can provide some guidance?
I would appreciate any help!
Thank you in advance.
Best regards
I wonder if Abaqus is the appropriate s/ware for this; you're trying to model the extrusion process, right? Does this involve hyper-elastic elements ? I'm sure it needs large deflections and non-linear material.
have you asked Abaqus help desk ??
thanks for your answer!
I don't need hyperelastic elements. yes, I have large non-linearities and deflections.
I haven't asked the abaqus help desk yet, could you tell me how to reach it
Abaqus help desk should be under "contact us" on their website, or maybe on your license agreement.
seems odd to get "excessively distorted elements" warnings and not need hyperelastic elements ?
or is Abaqus complaining about your mesh (and the aspect ratio of your elements ??
Thank you for your response. The material I am using is aluminum, so I am working with a plastic material model, not a hyperelastic one.
If Abaqus is actually complaining about my mesh quality, how can I determine that? I have already ensured that the mesh is very fine in the regions of high deformation, so I would not expect issues related to element size.
Are there specific indicators or diagnostics in Abaqus that can confirm whether the problem is due to poor element quality rather than material deformation?
yeah, IDK Abaqus that well ... if you're getting an error (a hard stop, not just a warning) there should be some way to see ...
1) what limits Abaqus is applying to element topology,
2) which elements are failing which test (it shouldn't just say "hey bud, some of your elements are so messed up that I'm not doing nothing") You may need to turn on some messages.
I can't see the mesh of the billet (where it distorts) well but it might be necessary to either refine it a lot or use a different modeling technique meant for extreme deformations such as CEL if the billet is supposed to deform significantly.
can you figure out which element is highlighted ?
