XR250
- Jan 30, 2013
- 6,001
I have a situation where a contractor wants to use tempered glass as an infill panel for a residential deck guardrail. The glass comes with a perimeter aluminum frame that then screws to the surrounding structure. The panel will fasten to the deck surface at the base and wood balusters at the sides. At the top, they want to run a 2x2x18ga aluminum extrusion from post to post.
When I check deflection of this top rail with a 200 lb vertical point load on a 6 ft. span, I get 3/4". The glass in the frame does not use a traditional silicone gasket like aluminum storefront but a heat bonded system. The sales rep says it may be able to take 1/4" deflection but does not guarantee that. Anyway, I want to make the top rail as stiff as possible.
I can fit a 1 1/4" ID pipe in there. Steel would be best as it is readily available and stiff. My worry is water getting in and having a galvanic reaction. Any ideas how to mitigate this? Also, the aluminum will have to deflect a bit before the steel engages. The contractor says the 18ga extrusion is the thickest he can get. I'm also thinking about just walking away from this.
