Numerical singularity error
Serbu
Student
Mar 3, 2025
3
I am trying to simulate a wind turbine model in abaqus but every time i try to run the job, the numerical singularity error shows up. I simplified the model to only have a blade and the nacelle (2 parts overall in the assembly) with the blade connected to the nacelle through a bushing connector (simulating the bolts). I applied a pressure distribution on one side of the blade to simulate the lift experienced by the blade and fix the nacelle with an encastre. I tried to apply more boundary conditions but the system gets overconstrained and although the jobs gets completed, the results are not saying much. Do you have any advice?
Numerical singularity is just a warning (usually occuring in undercostrained models). Are there any actual error messages ?
Apologies if I misunderstood you, but is your blade free to rotate about the bushing connector? Could that be a problem?
Due to numerical singularities the solver can’t solve the iterations and at some point after five unfinished solver tries it aborts the job automatically.
Well i thought about that and i put a fixed constraint at the other end of the blade and the solver completes the job but the results are not saying much ( cause now it s fixed at both ends basically). Do you have any ideas what constraint or boundary condition to put to fix that rotation?
I guess it depends on what are you interested in. If it is stresses in the blade, I would start with fixing rotation in the bushing. Have youlooked inte an example from Abaqus manual: Analysis of a rotating fan using substructures and cyclic symmetry
