pump control valve for high acidity
pumpmann
36
hello folks
for high acidity flow media ( high sulfuric acid content) what are the options for hydraulic operated pump control valves and surge anticipating valves?
who are manufacturers of suitable valves or alternative arrangements?
many thanks
You may want to talk to these guys in China
All big vendors should help you. let say Emerson and others.
Note: a better description of the chemicals within the solution will help us and you to get an effective support.
Use your favorite search engine, key words: control valve fluoro material
Pierre
  • utilisation H2SO4.pdf
98% sulfuric acid is OK to work with until you add some water. Then you could need some very exotic materials. We have applications that require Tantalum pipe spools at the point water is added. You do need to define the pH range of your acid.
"You do need to define the pH range of your acid"
Wow!
Pierre
