EngDM
- Aug 10, 2021
- 726
I have a slab on grade supporting some racking where the legs of adjacent racks are relatively close together, such that their punching cones would overlap. I am running the slab in safe, and after reviewing their documentation and contacting support, it turns out that they do not consider or check punching when the loads would overlap.
They did not offer any insight on how you would check this.
My first thought was to have SAFE check punching, and ensure that the summed utilization of any loads within slab thickness distance (clear from edge/edge of plate/punching application area) of eachother does not exceed 1.0. However this is likely overly conservative, as the loads would share 1, maybe 2 sides with eachother of they are diagonally spaced.
Has anyone thought of a rationale for justifying a punching check with loads in close proximity to eachother?
