1
- #1
Sparweb
Aerospace
- May 21, 2003
- 5,178
The developers of SMath have changed their terms and will be changing their licensing conditions soon. This will make it difficult to use for free unless you remain at version 99.7822. I first heard about the change to the licensing terms last year, and I’ve remained at 99.7822 ever since. Many of you will probably have later versions. Any version with 1.00 will work until they enable the licensing system, and then it will stop.
Many of you will be in a dilemma, because SMath is owned by a Russian company. Making payments to any business in Russia is a no-go zone for the foreseeable future. If this isn't a problem to you, then for the sake of hard-working software developers everywhere, convert your “free” usage of SMath to a paid subscription, like we do for all other software. I respect what Andrey and his team have built, and I did contribute until world politics went bad.
Rollback option:
It is possible to roll back your version of SMath. I did it on my home computer successfully. The process if fairly obvious: uninstall the later version and install the old one. To do the rollback, make a fresh installation of SMath from an installation file at version 99.7822. If you do not have a copy of this, it can be downloaded from the SMath website. I cannot guarantee how long this will be available. Good luck.
Before uninstalling your current version, run your current version and verify which version you have now. If you actually haven't upgraded from v99.7822, then stop now, you're OK. Once you have the old version installed, you will have a new problem at hand: opening files of later versions. This too can be dealt with. Stay tuned.
Rollback option:
