I looked a little further at your posted article. Some more thoughts.
I choose to focus on the ball freuqency sideband and not the cage frequency sideband. Here's why:
[ul]
[li]I can understand what a ball defect is and how it relates to ball defect frequency (also called ball spin frequency). Ball defect frequency is how long it takes the ball to spin around once. If there is a defect on the ball then it will impact a given race at ball defect frequency. Sometimes in vibration we see twice ball defect frequency appear because during a single spin of the ball defect, it contacts two races (inner an outer).[/li]
[li]I don't understand what a cage defect is practically (cages don't generally get discrete defects, they typically wear) nor how such defect would produce cage frequency vibration. Kinematically, the cage frequency is the rate that the cage moves with respect to the stationary race... if you took a photo of the rotating cage at t=0 and t=1/Fcage, the cage would appear in the same position in both photos. There is no impacting expected to occur at cage frequency under almost any circumstance (a defect in the cage may be continuously in contact with the ball as ball surface slides by, but there is no impacting associated with the cage defect like there is for ball defect or race defect). Cage frequency is of interest in the vibration world primarily as a modulating frequency for ball pass frequency. Let me explain what I mean by that. We place our accelerometer at at a given location adjacent to the outer ring. Then a given defective ball (which travels around the bearing at same speed as the cage) passes by that sensor location at a frequency of cage frequency. So the ball defect defect pattern measured at that location is impacting at ball defect frequency (or twice ball defect frequency) where the impact magnitudes increase and decrease at a rate of cage frequency (as the impacting occurs nearer and further from the sensor). The associated spectrum is harmonics of ball defect frequency (or harmonics of twice ball defect frequency) with cage frequency sidebands. Knowing cage frequency helps us recognize the pattern in vibration. It's not clear what the role of cage frequency might play in modulating a ball defect signal in current, since the aspect of the defect moving past the sensor at cage frequency no longer applies in current like it did in vibration.[/li]
[li]All of which is to say, I don't even know what exactly it is that is represented by this cage frequency sideband. They never explained it and there is no obvious physical connection.[/li]
[/ul]
... so I am inclined to focus on the ball defect sideband. Inspecting tables III and V for the ball defect sidebands, I see that 5 out of 8 ball defect measurements went up, while 3 out of 8 ball defect measurements went down! So it is barely more significant than the 50/50 split of 4 up / 4 down than we might expect from random variation... and that's the take home message for me.
The vibration does not suffer the same problem. All 8 of the ball frequency measurements went up in table VII and IX. And on top of that the changes from normal to damage level 1 and from damage level 1 to damage level 2 were much higher and more distinctive.
I know no-one here in the paper is claiming current signature is better than vibration signature for analysing bearings, but from this little bit of information, my first impression is that analysing by current appears waaaay less definitive than analysing by vibration for this particular defect. And speaking of "this particular defect", we should return to the point of my previous post which is that we don't even know the nature of this particular ball defect. We only know that it was created by drilling all the way through the cage. I would say it may have been quite severe damage to the ball after the drill penetrated the cage. So if the indication on current is marginal / questionable for this potentially severe ball defect, I don't have much confidence it would show for a more typical / less severe ball defect.
