Error in performing miStartSteelDesignCheck of Structure
F.Moghadam
7
Hello everyone. I have developed a steel-frame model in ETABS 18.1.1 using API. The model works correctly. When I try to design it, using an auto-select list, the model starts to design and it seems that one iteration completes. The model re-analyze itself and start to design again, but at the end of the second iteration, a message appears on the screen that says "Error in performing miStartSteelDesignCheck of Structure". Do you have any idea about this issue?
