Plastic ovens?
GearNut
Where can I purchase a plastic oven for doing small projects?
Mainly using for low thermoset plastic for small molds... For temps no higher than 550 degrees
Is their alternatives then the thousands of dollar ovens out there?
Thanks a bunch!
Oops, forgot that.. hehe
I wanted something to 550 F
You should check with used lab equipment houses and ask for a simple convection or drying oven. The less expensive ones are rated for 460F. They may be settable to 550F. I've seen some pricing online and they are more expensive than I remember, but a used equipment house may have something uncomplicated that will get you your temperature.
