hvaclearner
I would like to debate and arrive best pumping solution for this problem,The requirement is to pump water in 3 lakes located in at 1 km distance in a row for the irrigation purpose. The source of water is a circular tank around 15m high and there is common discharge(supply) pipe for all the lakes. All lakes are fitted with on/off valve and controlled by the water level in the lake. I want to design a pumping system which can able to supply the water in any lake depending on the on/off situation. There could be demand in one lake or in all lakes or all valves closed. I wish to go for multiple pumps running in parallel.Should I go for VFD or constant speed pump? What should be the control logic for efficent system? Please suggest.
