Turning off (or not) identical elements on dwg
I have 10 identical parts in line in the assy. On the DWG in one of the views I see only the first element the remaining 9 being in line are blocked by the first.
Question: Will the DWG load/"manipulate" faster if I go to the tree of that view and "turn off" (whatever the word) the remaining 9 elements ?
Thanks for the answers.
RE: Turning off (or not) identical elements on dwg
DWG is a standard AutoCAD drawing. I assume you are using a SW Drawing?
If so, then hide one the component that is blocking your view in the assembly model, or use HLV in th drawing to see the other components behind the single component.
If you Suppress the other 9 components in the assembly will work too.
Sounds like you need to use configurations in your assembly and use the appropriate Configs. in your drawings.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Suppressing the features in teh assembly will increase your SLDDRW load times.  Do as suggested, and look at creating a configuration of your assy with the hidden parts Supressed, then use this new configuration to create your drawings.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
