Fortran problem:Incrementally linked image
Hello everyone!
I'm programming a pretty large program with Fortran, and I have encountered the following problem:
When I compile the program, everything seems to be ok. Even the 'program's name'.exe starts and the program starts running. But after a while there comes this error message
forrtl: severe (64): input conversion error, unit 2, file D:\FORTRAN2\testi
Image PC Routine Line Source
LAPIL.exe 00425979 Unknown Unknown Unknown
LAPIL.exe 00425773 Unknown Unknown Unknown
LAPIL.exe 00424904 Unknown Unknown Unknown
LAPIL.exe 00424B7E Unknown Unknown Unknown
LAPIL.exe 004221DA Unknown Unknown Unknown
LAPIL.exe 004215BC Unknown Unknown Unknown
LAPIL.exe 00403081 Unknown Unknown Unknown
LAPIL.exe 00404445 Unknown Unknown Unknown
LAPIL.exe 00401622 Unknown Unknown Unknown
LAPIL.exe 0044FF79 Unknown Unknown Unknown
LAPIL.exe 00443D84 Unknown Unknown Unknown
KERNEL32.dll 77F1BB7B Unknown Unknown Unknown
Incrementally linked image--PC correlation disabled.
Press any key to continue
I don't have so much experience with Fortran, so I really don't know what to do with this problem, because everything seems to be ok, and still it gives me this.. I would really appreciate all the help you can give me to be able to solve this problem. My fortran is digital visual fortran 6.
Thank you.
Thank you.
RE: Fortran problem:Incrementally linked image
"forrtl: severe (64): input conversion error, unit 2, file D:\FORTRAN2\testi"
tells you what is wrong. That is the file D:\FORTRAN2\testi is being read with fortran unit 2 and the data in the file does not match the type of data that the program is trying to read from it. For example the file may contain contain character data and the program is trying to read an integer.
The mis-match has occured at some point within the data file, else it would fail immediately.
I think you're right. When I debug the program, the arrow shows to a line which says int 3. But how to correct this? I have went through my code, but I don't understand where that match error is. Does the debugger tell it somehow?
One other thought. I found that with Lahey Fortran, the LF95 version enforces a more strict match between READ/WRITE variable type and the format spec used. With earlier versions, one could write a real variable with an integer "I" format spec and the runtime would do the conversion for me. Not so with LF95. Look for that situation. Good luck.
