Drawing file size too large
I have an assembly file with about 500 parts in it and the drawing file for that has blown to about 26 megs (MB) in size and ittakes forever to open and also just doesnt print. It freezes and I cant print the file. I tried that from other computers too, but that doesnt help.
Now I converted that to a PDF which turned out to be about 8 Megs and for some reason I cant print that file either.
I am not too sure if it is my network or Solidworks.
RE: Drawing file size too large
A 500 part assembly at 26 Megs doesn't seem that bad to me.
What are your Assembly stastics say about your assembly?
What are your system specs?
Are you opening them up over a network?
If you are, then copy the files locally then and try to open it. You will see a significant difference.
Have you preformed routine maintenance on your computer (see SW FAQ in this Fora)
Run a search in this forum on this type of behavior (e.g. slow performance)
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
I have an assembly with 595 parts (591 resolved) that comes in at a "lite" 11.7mb. But I have 55 sub-assys, and only 22 top-level mates. The drawing takes about 15secs to open and rebuild.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Vik
